What will I need?
Slick68
Hello. My name is Matt. About 1 1/2 years ago, we picked up a used Yerf-Dog 32001 for my sons(10 and 7). It worked and ran well and really had no major issues for a couple months, then I started having issues with getting it to start, then stay running after getting started. One issue was spitting gas back out of the carb while trying to start(stuck valve in head?). We took it to a repair shop. He said the carb was the problem, and got it to work again, but said if it kept having problems he could get a replacement carb for about $70. It worked good enough for just enough time for the brake band to break. At that time(late summer), I put it away until I ordered the brake parts. I finally ordered the brake parts and replaced them this spring. Went to start it up, and it started spitting gas out of the carb again. I let it sit for about 30 min before I tried starting it again, at which time, I made about 4 pulls and the pull string broke.
After talking with many people, they don't recommend fixing the old Tecumseh engine. After lurking and reading a few things here, it looks like the Predator 212 is the best route for a replacement engine. My question is what else will I need, or will this be a simple swap?
Ok, the first thing I'm gonna do is try to talk you out of buying a new engine. If the tec is, essentially, ok, don't let little things like a blocked carb or a broken pull cord put you off. Seriously, these are simple fixes.
IMO, the major problem with the carb is dirt which is entering through the air filter; preventive maintenance is the key. Instead of having to clean the carb every few months, get yourself a finer filter assembly, do a thorough carb clean & you should be good for about a year if the filter is cleaned regularly
Slick68
I appreciate you trying to get me to fix what I have, but parts are becoming scarce or not available for the Tecumseh. Harbor Freight had the Predator 212 on sale for $119, so it's a no brainer. As my son gets more experience, we also may start upgrading the engine for more power. Since it's a Honda clone, parts are easily attainable.
I picked up the Predator 212 this past Saturday. For future reference, the Tecumseh has a 3" crankshaft snout. The Honda/clone engine only have 2 7/16". Here is where the issue comes in. The Yerf-Dog has a Comet II TC supported with a jackshaft. The sprocket setup is on the same side as the TC setup(left side). The driver end of the TC had an 11/16" spacer(same as small sprocket) to align the TC belt. So, with the new engine, the TC pulleys will not align, and the spacer does not allow the driver to be fully engaged onto the crank. To overcome this, I'm going to get a 1/2" steel(maybe aluminum) plate to serve as an offset motor mount. I'll have a machine shop drill and tap(for accuracy, because I'll screw it up for sure if I did it) the 5/16-18 chassis mounting flange on bottom, then offset the engine mounting flange 11/16" and possibly rearward if the 1/2" height causes belt length issues. The tapped holes will get 5/16" studs(with LocTite) so either nylock nuts or standard nuts with flat washers can be used for mounting both the plate and engine.
As I do this, I'll try to take plenty of pictures, so I can try to assist anyone else doing this swap.
Slick68
The only interference would be with the large sprocket on the axle. I'm not sure of the actual tooth count. The edge of the sprocket and chain is about 3/4" above the engine mount plate of the chassis. There's already a 1/4" motor mount/jackshaft mount plate, so another 1/2" should give me the clearance I need. If, for some reason, there's still interference, I can always add another engine plate, washers or shims to get adequate clearance.
Of course, I've always been a measure twice, cut once kind of person, so I'll be sure to double check everything before drilling and/or bolting things down permanently.
Slick68
OK, scratch all of that. None of that will work. :(
I've tried to get advice from several sources. I talked to a couple parts vendors, neither of which had anyone to answer any questions. Yesterday, I called to ask about some parts from www.gopowersports.com. A man named Gary answered the phone. He asked what I was working on. When I told him, he knew exactly the issue. He said as long as I still have at least 1/4" of the crank available to mount the TC driver, then it will work fine. I just need a longer bolt. He said that people have been doing this to Yerf-Dogs for years with no negative feed back.
Yerf-dog specially ordered their engines from Tecumseh with the 3" crankshaft, even though the industry standard is 2 7/16". That means this is a common issue when changing engines on Yerf-Dog karts.
souperman000
Westlake Village, CA
Glad everything worked out well.
As for the engine, you can play with the predator now, and use the Tec as an engine you can take apart, look at, fix, and use it as an overall learning opportunity.
