Hello. My name is Matt. About 1 1/2 years ago, we picked up a used Yerf-Dog 32001 for my sons(10 and 7). It worked and ran well and really had no major issues for a couple months, then I started having issues with getting it to start, then stay running after getting started. One issue was spitting gas back out of the carb while trying to start(stuck valve in head?). We took it to a repair shop. He said the carb was the problem, and got it to work again, but said if it kept having problems he could get a replacement carb for about $70. It worked good enough for just enough time for the brake band to break. At that time(late summer), I put it away until I ordered the brake parts. I finally ordered the brake parts and replaced them this spring. Went to start it up, and it started spitting gas out of the carb again. I let it sit for about 30 min before I tried starting it again, at which time, I made about 4 pulls and the pull string broke.
After talking with many people, they don't recommend fixing the old Tecumseh engine. After lurking and reading a few things here, it looks like the Predator 212 is the best route for a replacement engine. My question is what else will I need, or will this be a simple swap?
