Thank you all. I just got the motor on and I'm reading through the comments wondering if I'm in over my head. I'm assuming the driven is the silver part still attached to the kart?
You might be in over your head, BUT we are gonna pull you up, so you can breathe easy......
What you have, is half of a torque converter system. It's like a variable gear ratio automatic transmission for a go kart. You are missing the drive clutch.
You actually have 2 options here, depending on how big your budget is and how much diy you got in you. You can buy the drive clutch and a new belt,set it up and have some fun. The torque converter needs to be serviced/cleaned every 5_8hours of use, for proper function and belt longevity.
The other route would be to pull the driven clutch off, and put a standard sprocket. Then buy a $35 cent clutch (with free chain) and put it all together as a jackshaft assembly. Might be cheaper and you will still have loads of fun.
Keep the driven, for later, when you want "more" from your kart...... By then, you have enough bread saved up to buy all the parts you need to utilize the torque converter.
For future use...... CC or c c or cent clutch all refer to a centrifugal clutch (standard clutch used on street/yard karts)
TC stands for torque converter.....
See, you learned something already......
