What model briggs is this?
CoroTheCat
Builder
Denmark
I got this engine from a friend of mine. There is no carburetor , and the engine shroud is gone. I took the head of so I could inspect the cylinder, looks fine.
I hope that you can help identify this engine. The bore is 70,5mm in diameter (2.775 inches)
I will just post some pictures
I'm guessing its from a rotor tiller because it has two driveshafts, but I could be wrong.
KartFab
Dallas, TX
thats crazy lol. Makes me wonder if the main shaft is the crank and the other is probably attached to, or is the camshaft? Never seen that before.
CoroTheCat
Builder
Denmark
extended camshaft. They are sometimes uses as reverse on rototillers and snowblowers.
the small shaft does turn in the opposite direction. Maybe i could use it as a reverse gear on a gokart or something similar?
I don't know if i will use this engine, It is missing some parts and the crankshaft is a bit damaged.
Doug, with the head off, wouldn't it be easier to set the piston at BDC (Bottom Dead Centre) & measure the height of the cylinder wall?
Poboy kartman
Senior Moments Member
White Settlement Texas
From what little I have seen....that stroke is too short...5 hp should be about 2 1/8"....
Could be a 4hp?
Maybe someone can give a more definite answer....
