You mean a streaker kart?
I didn't even know some HAD diffs.
The Peerless 100 website just says 'grease'. Not too helpful.
If it says just grease, I assume standard brake grease or machine grease will do. It's not like a motor where it needs a specific oil for load, temperature, and design reasons.
Yea, that axle is gonna need a machine shop with a 100 ton press for sure. And when I do break it down everything is getting replaced. I did hit the rotors with a wire wheel even though you can't tell it. Thing is they work great. Way better than I would have guessed. That raggedy hunk of junk drives and rides good by the way. It is begging for repairs and upgrades and it shall have them! Those front tires and that raggedy Lifan engine are a must go for the garbage list!!!
BTW you don't have a Peerless 100. You have a Comet SCD-1. It states it takes Bison 1650 grease.
Thanks. Now that I know what it is I might be able to put the stated lube back into it the next time it gets torn down. For now it has Green Grease waterproof gear lube in it. It's what I had laying around at the time and for now it will have to do.
