what kind of 2 cycle is this?
big pimpin
i'll get pics up when my cam works
on the carb is says "w18a" under that it says "54". on the bottom it says"zama" from what i can tell it's a c1u. but that means nothing as i dunno what it goes to.
on the engine it says 3453 lot c, then over more it says 530-012581 rev b. and on the casting by the intake it says 12519.
the flywheel says 15-567 "walbro "
the coil says 545-024901 then below that it says ma-73 1235 "walbro"
and the plug is a rcj6y
847
big pimpin
well, can i upgrade it? i have a walbro wt-312 carb ... not sure how good that is. but yea, it's way bigger, diameter wise. can i put the regular x-tube on it? was also wondering if my stock carb would take a volocety stack, or if the 312 worked, if i could find a stack for that.
847
big pimpin
well, i figured the spacing would be around the same for the x-port. but if not, yea putting a hole in the muffler. goin' to try out tomorrow or in a few days about the walbro carb. i think i may need some ether for this one :) tried it tonight, seems to flood the crap out of the cylinder.
Kenny_McCormic
Kartless....
Michigan Troll
Sounds over carbed, probably gonna need adjustment.
847
big pimpin
can you reccomend? also which way is correct for ignition? i tried clock wise and counter clock wise... got a few pops on counter clock wise .. i think? how many turns in on high and low needle? thanx
also, clock wise, the muffler was on the left, using forward on a drill, counter clockwise was reverse on the drill.
