What Clutch to Use?
I say go for the 3/4".
I think KartFab has a 40 series TC on a big block with a 5/8" jackshaft.
Maybe I missed something, but for a TC system with a 1" driver and 1" driven I think it is going to cost you more than 60 or 70 extra $$$. I was thinking hundreds and hundreds of $$$.
Show me the links of what you were thinking of using.
---------- Post added at 09:33 PM ---------- Previous post was at 09:27 PM ----------
As J-405 pointed out. A 1" Jackshaft needs a 90D driven unit...For use with 94C, 780, 770 Series and others requiring 1-3/16” TW Belt.
About $400 with no belt, as far as I can tell.
ChuckChapman
Chandler MN
New and confused
Hey I’m just new to forum stuff and I have been following along a bit. I have a 14hp engine with a 1 1/8 output shaft and can’t locate a clutch. Is it possible to put a centrifugal clutch on the driveshaft rather than the output shaft?
Slabach
Slabach
Virginia
ok, i'll just have to spend the extra bucks to get the good tc then...
Btw, (This is not about TCs) The steering of this go-kart is going bad and I need to completely redo it. Got any suggestions? Also, the paint is peeling so I need t get it off, but I don't know of any way other than to just grind the whole thing (blah!). I don't have a sand blaster. And I need to repaint it with something that won't peel like the existing paint.
Slabach
Slabach
Virginia
Try this
