went out with my buddy, and my bike has carburetor problems...
mark20
minnesota
i went out with my buddy today (it was a blast, a 125 4 stroke is faster than i thought! :thumbsup:) but near the end of a 2 hour long ride (i was pushing the limits on the baja lol) the carb started leaking, bad... i replaced the fuel line yesterday, because the old one was rotten out (and also leaked before this) . it stops leaking when i shut the fuel off. and when i try to gun it (started, and fuel on) it back fires, like its really rich (it sounds like its coming from the airfilter, not the exhaust) but 60% of time it runs great! im thinking its a stuck float. any other ideas? ill try to fix it tomorrow, see if that solves it, in the mean time. anything else i should do?
JTSpeedDemon
2019 Build Off Winner!
Texas
Yeah, sounds like a float problem. The old float I pulled out of my Briggs flathead had a big DENT in it that looked like it was caused by brute force. Still puzzled, since the guy I bought the kart from says he built the kart with his brother as kids. Says he never changed the air filter(ugh), so I don't think he ever disassembled the carb, but I could be wrong. It was also missing a carburetor body gasket. Check your carb very carefully, could also be some kind of busted seal.
mark20
minnesota
thats the wierd part, everything looks new. the seals look fine, i replaced them just incase. i got it to a point where it only leaks if i shake it (like a glass of water) im still confused on why it leaks, :surrender: ive done everything i could to it. im just going to leave it as is, ill probobaly replace it soon. :thumbsup:
JTSpeedDemon
Texas
Now THAT's weird. You're probably taking the safe route by just replacing it. At first I wanted to replace my Briggs updraft carburetor. Then I found out that an OEM carb is about $90 on Ebay.
