Welding... Minimum power?
spider87
I would like to learn to weld so I can build a frame. I don't have a lot of cash. Therefore, I'm looking on craigslist at welders and stuff. HOWEVER, I have no idea what to look for... Is there a minimum type of welder you must have to be able to give your frame strength?
:huh:
spider87
Well, as it's not a vital thing(meaning just a side project), I'd say sub $100 with sub $50 preferred.... I'm sure that's laughable though. But, I'm hopeful at least.
Hendu3270
banned
Pearland, Texas
Yeah, you'll be pretty hard pressed to find a welder in the $50 class. However, you can pick up a Harbor Freight 90 Amp Flux Core welder for $99 and it will have plenty of power to build a frame for you, (after a little practice of course). You might find a used HF 90Amp on Ebay in the $50 range but they are so cheap to begin with I personally wouldn't buy a used one.
crazyman
Yorkville Il
Practice on scrap pieces. You should hear a nice constant sizzle if the wire speed and heat is set right. I prefer to lay my bead in a C shape, then overlap it with another C.. CCCCCCCC.
Makes a good strong weld. Make sure the weld penetrates deep enough or it will break.
devino246
Official DIYGK Chem Nerd
Lynchburg, VA
Hes asking about buying a welder, not how to use one.
spider87
I think for now I'll just purchase a cheap used frame from someone and go from there. I don't have the money to invest in the welder really right now anyway. Thanks for the help guys.
spider87
redsox985
PA
Try the first, there's not a whole lot that can go wrong with a stick welder. It's pretty much a large power amplifier. If you go to buy it, ask to test it. It is a Sears product so it isn't cheap Chinese crap.
Gillgamesh64
Griffith NSW Austraila
Yeah i agree with redsox you are mutch better off buying a brand name second hand unit over a cheap new one any day, and with the cash you save you can buy a whole bunch of extra welding rods and grinding disks... Also if you buy a cheep 90 amp welder it will be limited to a 2.6mm rods, have no idea what that is in inches but it will do most jobs for a go kart but the problem with the small machines is they overheat very easily and once they are hot they will work for small periods of time and than cut out again leaving you frustrated and waiting, That sears machine is a great buy it will out perform and out live any cheap welder out there, And as for learing to weld get a welder read up on a few tips on welding and than go out and start welding things together spen a good afternoon on your welder pacticing before you start to attack your kart, and also dont use galvinized steel if it's thin as it tends to be more tricky to start with!
spider87
Question, how do I test it? If he does still have it and I go to check it out, how do I test it?
