Welded axle questions
luckyluckey
Redding Ca
I have someone who wants my axle and sprocket.
The axle is tack welded to the frame.
Is there an easy way to remove the welds to free the axle?
Or is there more to it than just that? I took the bolts out already.
luckyluckey
Redding Ca
Looks like it but up close you can see the spot welds.
I am sorry, but i still see spot welds on the hanger. There is nothing welded on the axle itself. The axle goes through a bearing that is held by the hanger. There is no weld on the axle itself
Edit: The circled areas in the pic are the hanger. The axle will slide through the bearing which is held by the hanger
luckyluckey
Redding Ca
Here's an even bigger picture so you understand fully what I am asking.
crazykart
Crazy member
Swartz Creek, Michigan
Take off the wheel hubs, losen the sprocket hub, taje the locking collars off, and slide the axle out. You will probably have to clean the axle up (wire brush or brill pad) and spray some penitrating oil (pb blaster etc.) And work it back and forth, but it should just slide out.
Poboy kartman
Senior Moments Member
White Settlement Texas
Clearly in the middle pic....I see you haven't loosen the allen headed set-screws....those need to be loosened.....better yet removed !!!
Then shoot PB Blaster on both sides of those collars and in the holes where the set screws were....
As mentioned, wire brush the axle, and work those collars free....
BTW: You were obsessing on those welds...and were not asking how the axle was removed.....at least not at first....that shouldn't hinder the removal....(although it doesn't make it any easier...
Poboy kartman
I agree. What was the story about the welds?
Well...if you look....the 1/2 of the clamshell bearing carrier..is welded to the frame....
Normally, this would be bolted to another plate welded to the frame with a slot in the bottom.....(unbolt the carrier halves....and the axle will drop straight down without moving any of the collars).....Soooo...yeah....it does make it more difficult....but doesn't keep you from removing the axle....
It's that someone short-cutted a mounting plate...and used a bearing housing instead......not as bad as welding to the axle, but still a needless PITA.....
