I was able to dig up some more info on the trike frame. I was told it was home built back in the 1950's with a scooter front end. It does have a name stamp on the front wheel spring bracket, I'll check when I get home. Right now it has a 2 speed gear box. I bought the trike with no motor but I was told it had a 5 horse on it. I went throught the honda motor and found too much wrong with it to continue the rebuild. I picked up a liquid cooled 1989 Kawasaki kdx200 2 stroke which should make 37 hp with a 6 speed trans. I'm probably going to use a rear axle and tires off a banshee and I have a friend who is making me some fiberglass fenders like the ones on the trike now but bigger to fit the new axle and tires. Also I just got 1959 Cadillac rear bullet tail lights to put the back. I was planning on using the front and rear sprocket off the dirt bike but if anyone can recommend a better rear tooth count. (I have a buddy that makes gears). As soon as I get so time away from work I'll post more pics. Thanks
