Weird trike and a cb350 engine
frog
Downriver Mi
I went around the garage sales this weekend and picked up this weird trike and a cb350 motorcycle in pieces. I'm going to try and use the rear sprocket from the bike. So now I need to figure out what diamimeter axle to replace the one that's on there that will hold up to street and yard use and what would be a good tire size. I'm not looking to go over 40mph but I do like to do wheelies. This is my first attempt to make a cart any help would be appreciated. Thanks
TX7
Northeast Ohio
That's gotta be an old trike, it would be cool to find out what engine came on it originally, and restore it to original specs.
Ditto. That's a cool old trike/servi-car type of thing.
Any hope in ID'ing the manufacturer?
oh.. that cascade and the front fender very much remind me of a Lambretta LD..
(57' lambretta LD)
the frame itself looks more to be from a cushman eagle or something..
('57 cushman eagle)
late fifties seems to be settled ;)
(btw if that is a lambretta.. it'd be worth 2 grand at the very least around here as it sits)
frog
Downriver Mi
I was able to dig up some more info on the trike frame. I was told it was home built back in the 1950's with a scooter front end. It does have a name stamp on the front wheel spring bracket, I'll check when I get home. Right now it has a 2 speed gear box. I bought the trike with no motor but I was told it had a 5 horse on it. I went throught the honda motor and found too much wrong with it to continue the rebuild. I picked up a liquid cooled 1989 Kawasaki kdx200 2 stroke which should make 37 hp with a 6 speed trans. I'm probably going to use a rear axle and tires off a banshee and I have a friend who is making me some fiberglass fenders like the ones on the trike now but bigger to fit the new axle and tires. Also I just got 1959 Cadillac rear bullet tail lights to put the back. I was planning on using the front and rear sprocket off the dirt bike but if anyone can recommend a better rear tooth count. (I have a buddy that makes gears). As soon as I get so time away from work I'll post more pics. Thanks
