Wanted briggs and stratton carburetor
solomon
ca
I need a carb that will fit on an 8hgp engine. The "updraft" style one. It is the carburetor that attaches with an elbow
solomon
ca
Actually i cant find one their, i was hoping i would. If you can find one, please let me know!!! Its gonna be 135 out the door for a new one, and honestly its not worth it to me.
solomon
ca
yes, their are 3 screws. Their are 2 adjustment screws , 1 by the butterfly area and 1 diagonally at the bottom. Thanks!
solomon
ca
The reason for a new carburetor is because the old one cant be taken apart due to a stripped threads and a stripped jet in the bottom part (hi speed jet). Do you think its plausible to dill out the old jet and threads, rebuild carburetor, then use a heli coil for the hi speed jet threads on the bottom of the carburetor? Thanks
anderkart
Surprise Arizona USA
I dont know if you'd find any Helicoils to fit your jets thread pitch/size but you could check around.
I was thinking you might be able to find a new main Jet with a bit larger outer thread size, then tap yer carb out to fit it. If the new Jet was sized too rich, you could just solder up its orifice and then re-drill it out as necessary to correctly jet your engine.
If your carbs other stripped threads had enough meat around the holes, you could probably tap these out to the next larger size too.
solomon
ca
i think its a 5/16" fine thread jet. Do they have helicoils like that?
solomon
ca
I saw some helicoil's at kragen for 50% off so i wil lchekc thier, but do you think gas would leak around the heli coil?
