mr gunby
I have a slightly modified dingo I would like to lengthen the wheel base by 3 inches. open for suggestions. hoping it will help reduce its porpoising tendencies. the extra legroom will be nice also.
If you do anything poorly the end result is poor.
lets start with I'm 51 and I am pretty adept mechanically and mathematically. I understand that cutting the frame in the middle will change the angle of the outside rails. sleeving the tubes is given approach. I also stated in my first post that I wanted to lengthen the wheel base to possibly help with the porpoising tendencies of the dingo. I have added a 16 hp engine an its mass to the back side of this machine witch has amplified this.
I did ask for suggestions, not opinions.
The issue here is clearly me! I do sincerely apologize. Having bad and expensive ex-wife days, not an excuse to behave like a jack***.
Wai till you meet my friend Doug!I've got this! hostility noted.
Just kidding, apology noted. We have fun here poking at each other.
