Photos and Video:
https://onedrive.live.com/redir?resid=EF997A0CE0CD14D9!2505&authkey=!AAhWUVtzX99_d1U&ithint=album%2c
This is a Briggs 5hp Flathead (RaptorIII) from '99, i raced it about half the season and it's been inside dry storage ever since...it ran fine when I put it up…so about 15hrs of use, 15 yrs ago.
Now I have it back, and problem is it seems to be bogging or loosing power upon the clutch engagement, it won't hook up accelerates very slowly, and is overheating the clutch.
Without any load, when I give a small amount of throttle, it hesitates and grumbles just above idle, but it will rev freely after that.
But under load (when I’m riding), the RPM seems to go just above clutch engagement and hovers there quite a bit, just doesn't break through and hook up. The kart accelerates slowly, eventually coming up to speed. (See Video in link)
Also by looking at the video, seems like alot of ping/popping going on, maybe detonation? Or that could just be loose chain skipping sprokets…I can’t slide the engine fwd any more, so I need to get a chain breaker and remove a couple links.
Initially I thought this was just clutch slipping, but now seems like power issue...please give some advice!
Carb is cleaned, fuel, oil and spark plug are new, and everything else is OE.
Some prior suggestions were: sticky valves, or worn spark plug wire.
I've pulled the head to check the valves, both seem tight. The intake doesn't tighten up fully until compression stroke is about halfway up - i believe that is a pressure relief that is designed into the camshaft but I could be wrong there.
I went ahead and sprayed a generous amount of WD-40 down the valve stems.
With the valve lifted, they do turn but takes some effort, it's not very slippery...lubing them up seemed to help some - i'm not sure how tight or loose they should be, but I understand that under operation they're supposed to rotate around on their own.
The valve timing seems OK to me by looking at it.
Also located a rough spot on the spark plug wire under the blower cover, (photo and video of that too)... . It doesn't look like much, but i suppose it doesn't take much for Mr Sparky to escape. I'll try to test with some soapy water spray today, and/or put a couple layers of shrink tubing over it.
Also will try to get some video of startup/idle/RPM ranges.
If you guys can think of anything else please let me know! I mean basically it seems like it runs fine until i actually get on and ride it...it seems to have good spark, compression, gearing is good...i'm stumped!
Again, all the photos and videos are located here:
