Videos - Flathead Bogging Down - Briggs 5hp
KartFab
Dallas, TX
so engine has no get up and go, pressure is 60 (which i kinda think is on the low end, but its a briggs flathead, they have low compression to start with compared to the OHV engines).
If piston rings were the problem, you would see a jump in psi after adding oil. Maybe the valve(s) not closing/bad seal/warped are the issue? Man I feel bad for you, but keep trying, there will eventually come a time when you will be like UHH FINNAALLLYYYY. not a leaky/ blown head gasket is it?
Might want to take it to a mower/small engine shop (after exhausting your options) and talk to the head guy and tell him your woes, see what he thinks.
Kokamo
Azzkicker extraordinaire
Liberty Hill, Tx
I've seen a ACR fail and keep letting the compression bypass under normal running RPM's. I'd just remove the dern thing while I was in there.
Just a thought!
~Joe
