robbie
I've seen several photos of vertical shaft engines converted to horizontal shaft, and in all cases the cylinder points upward. Is there any reason why I shouldn't orient the cylinder horizontally?
Did you not even read my post regarding how are you going to keep oil in the engine?
No prob man... you get what i mean?
I guess the thing to do is take it apart. It's been a while since I actually looked inside one of these. It should be fairly obvious how to get the oil to work right once I have it opened up.
As long as I have to build a new intake pipe anyway, I'm thinking of using a brand new Honda carburetor rather than the old Briggs carb. We had several of these old 8 hp Briggs engines back in the 70s and 80s when I was a kid, and the carburetors always had a little bit too much "personality".
Is it a common problem for the oil to leak past the rings in a normal vertical shaft engine?
