Valve/timing issue
Please try to keep up. ....re-read the previous post. ."I also put new valves in..."????
:oops: Ok, my bad, I must've missed something the first time...
Since replacing everything, the valve timing could be off so, back to my previous post about clearances, that's something else to check...
Mrenglish90
Ocala fl
Sounds about right. I ordered a new head with valves yesterday. Threw in some new rollers too, mine look like a dog chewed them. Hopefully after receiving and install it will come to life.
Mrenglish90
Ocala fl
Ok, new head with valves came in. I installed them last night, reassembled everything, hooked up the wires made sure it was timed properly this time, charged the battery made sure there was gas..... But still no start:censored:
There's a ton of popping and a little backfiring...and even a small engine fire (which was quickly put out before there was damage) but that freakin thing didn't start up!
Any ideas?
Poboy kartman
Senior Moments Member
White Settlement Texas
Any ideas?
Yes....describe how you timed it in detail. ...because it smells of a timing issue. .....
If you did it once........jest sayin'......let's make sure. ...and put that to bed first!!!!!
Mrenglish90
Ocala fl
Okay before i put new head on i put the piston at the top of the cylinder, marked the position on the flywheel, put head on and made sure my marks lined up, and that the cam marks were set to tdc as well.
Mrenglish90
Ocala fl
It may be my carb... But i dunno.. the hardware that opens the butterfly when you hit the throttle is missing... I'm guessing its a fuel air ratio thing... I also don't have the tall pipe on if that makes a difference...?
Poboy kartman
Now when you put that piston at TDC....the magnets were right around the magneto....right? ????
Someone correct me if I'm wrong. ...but doesn't that piston come to TDC....twice? Once on the compression stroke.. (when the cam marks should face each other) and again when it's on the exhaust stroke..... (when the cam/crank marks may not line up).....
What I am trying to say is that while the cam turns twice for the crank's once....the valve timing will vary...and the exhaust may be off a couple of teeth from lining up. ...so if you line it up that way....your timing will be off....
Mrenglish90
Ocala fl
So your saying i have to rotate the flywheel around till the piston is at top another cycle, and then put the cam in?
Uhm..
partly correct, just the other way around;
while the piston isindeed twice at TDC per full cycle (one cycle being from one ignition to the next - two revolutions of the crankshaft)
the camshaft makes just one revolution.
BUT, the cam doesn't care wich TDC the piston is at (first or second per cycle) since the magnets is on the crankshaft it'll still ignite and valve timing is still alright.
Just think about it.. it's a 2:1 ratio it doesn't matter if its 1,3,5,7 or 2,4,6,8
counting the TDC passes.
Since which pass is which stroke is determined by the Cam, not the piston.
Anyways, since this is an overhead Cam engine it's a bit of a pain, since there is no direct markings to line up against;
you need to rely on what you have..
On the flywheel there should be a T and an F mark...
when you assemble the engine (as you do right now) move the T under the tab.
And install the cam exactly like this:
The T mark will drift ever so slightly (away from the F mark), no big deal :D
If you moved the magnet under the magneto the timing will be WAAAY off (~30°)
So never mind the magnet ;)
Oh one more thing, while the head is still off... make sure you have the piston the right way around;
it DOES matter!
(THE EX means EXHAUST, so that needs to be unter the exhaust valve of course)
otherwise you'll bend your valves again :(
Mrenglish90
Ocala fl
Ok well when i assembled i made sure the piston was facing the proper way. I lined the cam up at tdc with piston but earlier in the rebuild i moved the flywheel around and didn't think it had a specific position... So when i put that on i have no idea if out was on in the same spot... Also i see no t or f on the flywheel...
Poboy kartman
For clarity...
Whenever TDC is mentioned in regard to VALVE timing, that means that both vales are COMPLETELY CLOSED and engine is on the COMPRESSION CYCLE.
And the magnets on the flywheel should be right around the magneto because it needs to fire at about that time......
Of that there can be no doubt. .....
Mrenglish90
Ocala fl
Ok I'm an idiot... I was looking for the t and f on the face of it. they are on the side... Maybe that's what is wrong... i may have put flywheel on in wrong position. The cam and piston are at tdc, I'm sure of that. If they are at tdc.... Where should the t and f marks be pointing to on the case?
Mrenglish90
Ocala fl
Flywheel is in correct position but ... i got it to start twice but as soon as i let off the ignition for the starter it died immediately... And now after the last time for some reason it isn't sputtering or backfiring. Its almost like i lost compression again : (
This thing hates me. Who wants to come help me drop it in the ocean?
