Mrenglish90
Yes there is one light indentation at the top of the piston..
You don't think I should replace it as well do you?
Please try to keep up. ....re-read the previous post. ."I also put new valves in..."????
Ok, new head with valves came in. I installed them last night, reassembled everything, hooked up the wires made sure it was timed properly this time, charged the battery made sure there was gas..... But still no start
There's a ton of popping and a little backfiring...and even a small engine fire (which was quickly put out before there was damage) but that freakin thing didn't start up!
Any ideas?
Exactly backwards.the cam turns twice for the crank's once....
Someone correct me if I'm wrong. ...but doesn't that piston come to TDC....twice?
...so if you line it up that way....your timing will be off....
For clarity...
Whenever TDC is mentioned in regard to VALVE timing, that means that both vales are COMPLETELY CLOSED and engine is on the COMPRESSION CYCLE.
