Unknown project
spc13b
Goldsby, OK
Bought this go kart for $40.00. It came with a tecumseh 6.5 hp engine that has good compression and spark. The carb is gunked up very bad. Can anyone tell me what this cart may be?
2SlickNick
American Minibikes @ FB
Mesa, AZ.
Looks like a 150cc or 110cc mini buggy front end fused with a dead axle go kart.
Custom hybrid maybe
Pics of the front end help too.
Axx3d
MN
No idea but it looks fun.. a place to put a cooler full of steveweisers when you hit the trails..
spc13b
Goldsby, OK
It has a swing arm rear end. I am planning on taking the original one off in rebuilding a new one. I would like to move the engine to the center and run a live axle. I would also like to remove the center shock and replace it with a shock on each side of the swingarm
Bucfan1512
Oklahoma
Hey SPC, glad to see a fellow Oklahoman has found the site. I hope the knowledge these fine people have helps your in your project and cant wait to see what it turns into!
In no way does DIYGK condone this type of activity; drinking & driving, in any situation, is just plain dumb!
None of that seems too difficult, although, IIWM, I'd re-engineer the existing swingarm as opposed to starting fresh...
spc13b
Goldsby, OK
Fabroman. I was thinking about what you said by modifying the rear swing arm instead of building a whole new one. That is most likely what I will do. It will save a few extra bucks
spc13b
Goldsby, OK
Well I went out to the shop today and tinkered a bit on the buggy/kart. I removed the rear shock and swing arm. I will try to post some pictures tomorrow before I head in to work
spc13b
Goldsby, OK
I will be using most of the original. I just want to get rid of the dead axle and install a live axle. I am also looking in to using golf cart wheels and tires since I have a set of those in the barn.
spc13b
Goldsby, OK
I have looking all over about this kart. The only one I found that resembles this kart is a carter kart. I will post a pic soon
First, carefully cut off the engine mount then, IMO, you need to remove the sections marked in red in the pic below; this will create areas for the sprocket & brake disc on the new axle; don't just cut them off, you need to create a flap to close off the tubes; given the shape of the frame, this should keep the strength in it
