UK Arachnid build
Wobbly
UK
**** it. The only way out of this one is to buy a wider rear axle. The one I have is about 40" wide but I have found one on eBay that is 45" wide. That means I could increase the wishbone length to approx 12.5". Any good?
theo
Make the a arms full length, use skinny trailer style tires on the front and reverse quad rims on the rear. This should overcome most of the front width, but wider front to rear should make the buggy stabler at high speed.
Wobbly
UK
It's my own fault at the end of the day, I went out and bought lots of components without really understanding the principles. Think I'll stick with the plans and see what happens. Would it matter if the front wheels are wider than the rears?
fowler
Bullsbrook West Aus
love being of the few aussies because there is only a cople of asians and no russians (i think so) so most of the paticpants are in bed when im on
Bill CNC
So. Calif. Desert
What the hell, ... you actually have seen this site fast?
Hell, .. my screen times out, 1/4 of the time because I have to wait so long and I have a high speed cable connection. I thought it was the norm that this place had slow servers.
Slow or not, ... it's nice to have this place around. :thumbsup:
Wobbly
UK
Just been Googling for some info on how to install an advanced timing key for my GX390 clone, and stumbled across a very interesting PDF guide HERE It goes into lots of detail on how the engine operates and is full of some very useful info.
Wobbly
UK
I've been working on the steering rack mount today, with thanks to Mikko for the rack :) Fabricated a simple bracket from some 2.5mm plate, welded to the cross member which I'll weld in place once I'm happy with the location. The rose joints line up nicely with the wishbone axis points, so hopefully that's the rack problem solved. Thanks to all those that helped me with this, it was very nearly the straw that broke the camels back in this project. A couple of pics...
Wobbly
UK
Thanks Bill, it was a nice job to do. I do have the boots, just had them off while I was working out the width. There were two aluminium bushes in between the rose joints and the rack which I removed to reduce the width a little more. Made a start on one of the wishbones today, now that's a tricky job.
Bill CNC
So. Calif. Desert
Ahhhh, ... The wishbones.
Just clamp the heck out of it along with getting the fattest lady you can find to sit on it. The real trick is to try to find a spot to weld! ;)
With that many clamps blocking your way, ... well you get the point.
Again, ... GREAT JOB!
Wobbly
UK
I'll spend some time making a jig first thing tomorrow, and clamp the hell out of it!
Wobbly
UK
Got one wishbone welded up and it wasn't too bad, although I spent quite a lot of time making a jig which really helped. I have another question for you all though. My plan at the moment is to weld a small plate over the open end of the wishbone with a tapped hole and then weld a nut onto that for the track rod ends (clevis joints in my case but you get the idea). The track rod end will then screw into both for some added strength. My question is, are coarse threads OK or should I really be using fine? The reason I ask is that the track rod ends I have are coarse and it would be awkward to exchange them for fine.
