I like the acetone trick. The kart looks cool it should move pretty good with that on it.
Yea, just be careful if you try this...I cant say this enough and never use a slow vaporizing fuel like gasoline...
I was doing this with an old Tecumseh and it had an intermittent valve sticking that I was unaware of and I burnt the hair on my leg and set my shoe on fire. Could have been worse. So it does have its dangers.
That's a big engine. I think it would be great for a buggy or 2 seater but might be overkill for a standard kart so I'm not sure what I am going to do with it yet. I find that a 212 will move a large kart along fast enough even with the governor in tact if the gearing is right.
Here is a stage one predator 212 on a Murray Explorer. No tricks and governor still in place. As you can see it goes along pretty well for a big cart carrying a big man. I am 6'2" 285 pounds so...
part 1 and part 2...I couldnt figure out how to merge the files...stupid camera
https://youtu.be/nqptSH7hQbI
https://youtu.be/eubg6JaiF5o
Wes
---------- Post added at 12:23 AM ---------- Previous post was at 12:01 AM ----------
Oh yea, and don't pour it into the fuel tank, or into a carb...acetone doesn't play nice with rubber lines, gaskets, and o'rings...most plastics either...
I'm just saying all this in case someone tries this...I don't want anyone hurt nor do I want anyone's property damaged...
It's one thing to say don't try this at home....it's often a good reason to say why. Some of my more experienced and knowledgeable fellow mechs know this, but then some don't.
All said and done...
Play on playas!
Wes
