Brandon1023
needs an oil change
Honda GX390 Clone Generator This one went through 2 carb cleanings, the usual lemon juice bath for 20 mins, being blasted with carb cleaner, etc. The Jet, Emulsion Tube and passages are clean for sure. It will start up in a few pulls, and then it will surge. I have adjusted the gov. screw and used my Tiny tac to keep it around 3600, but it runs rough. In the video of it below, you need to turn your volume up loud to hear the way it surges. I'm not really sure what can be causing it since the carb is clean and fuel is flowing. If anyone can give me some pointers, that'd be great. I'm thinking something in the carb is still dirty since it sat for a loooong time with gas in it, but I can't seem to find it. As mentioned, the jet is clean as can be.
http://s1247.photobucket.com/albums...on=view¤t=video-2012-06-15-20-17-12.mp4
Briggs Lawn Mower Carb
This one is an issue with the carb on a lawnmower. I cleaned it with my mentioned steps above and put it back together. Once connected to the tank, gas will flow from one of the holes on the choke side of the carb. In the picture, I pointed with the pink wire. The needle is seating and I know that b/c I can blow air in to the fuel intake and when I push up on the float, the needle plugs in to the rubber seal. All the parts have been changed with a rebuild kit.
