pRoFiT
Can't buy it?, build it!
After months of searching for great priced mini bikes I finally found a great deal. In fact I found two. Guy wanted $175 each. Ended up getting both for $315.
Both need gas changed out and carbs clean. Some gas lines are old and cracking. One needed pull start fixed
The first one has modified predator engine. Sounded fast. Will need to clean up and see if I can safely test theses out tomorrow.
So far even if I have to replace an engine I think I did good.
where do i start on this one. new coil and somehow replace magnet? anyone do that on the predator engine? just a screw? nut bolt? glue? jb weld? ill research it. reply if you must
