Nodroz
Hello guys,
I had some problems with my screw's threads on my engine. I didn't want to replace the whole case, so I decided to re-thread.
Tools needed (See the pictures. I don't know the English names, sorry. EDIT: Thanks to r-chez, the tools now have a name!)
Helicoil tool
Tap and tap wrench
Helicoil
I have found all these tools in my local repair shop. He gave me his tools for 1 day so I could fix it myself.
1. Get a tap and a tap wrench. Be sure it's the correct size for your hole! Mine is an M10. However, this is slightly bigger than an M10. You make the new thread bigger than the previous one. Then thanks to the helicoil, the thread will be back to a normal M10.
You go very slow, in clockwise direction into the hole. DON'T do this with an electric bore. Simply DONT. Be sure you're going straight in the hole. You don't want to go a bit skew and you'll completely ruin it. To get it straight it takes some time and patience. Just slowly turn it and watch what you're doing. Once you got it straight in for about 2 cm, you're almost done. Keep turning the tap wrench slowly in the whole to make your thread. Don't forget to oil it often, so everything goes a little bit smoother.
Go as deep as you need to. It's better that you go a little bit deeper than it should be. Once finished, slowly turn the wrench back out. This shouldn't be too hard.
2. Once finished with the re-threading, it's time to get the helicoil inside it. These are special rings designed for this. You screw it in and when you're sure it's at the good location, you turn counterclockwise. You'll need to put a little bit of force onto it. Suddenly the little pin that's used to get it inside the thread will break off and your thread is done!
(You can see the little nipple. That's nothing, once you screw in your screw it'll gone.
This proces takes time and patience. But it is cheap and better than replacing the whole engine's cover just because for new threads.
I hope you understood a bit of my explanation. It is quite hard to explain something like this in English for me, though.
Hope it helped!
Regards,
Nodroz
Helicoil tool
Tap and tap wrench
Helicoil
Hope it helped!
Regards,
Nodroz
