DMCdesign
Master Apprentice
After doing many research on how to tune the engine to full potential, here are some of the tips I have compiled from the following sites- affordable go karts and ehow.com
Governor- while many people feel removing the governor is a surefire way to increase performance, but the governor does a lot more than that. Not only it controls the RPM, but it also controls the throttle to keep it steady. If it bogs down, it opens up the throttle and if its over revving, it will relax the throttle. Tweaking will also help which will not only allow higher peak RPM, but also keep the RPM uniform.
Valve springs- after the increase in performance, the stock valve springs will not be able to handle the load and will float- which we all don't want. Getting stiffer valve springs is a fairly inexpensive performance investment.
Flywheel- in some engines, especially clones, the flywheel tends to detonate at higher RPMs. needless to say, It is similar to a bomb going off. If you haven't got the buck to switch to an ultra light aluminium flywheel, Bionically Optimise it! This trick is used by BMW for its diesel engines which consists of cutting off the "body fat" from stock parts to make it lighter (ex-remove the fan). Not only you get a lighter flywheel, you have practically paid no money for it! Bonza!(however this is not recommended if you do not have the appropriate balancing machinery to check balance of the flywheel- which is more dangerous than a stock flywheel detonating)
Polishing and Porting- this classic tuning method consists of grinding out factory imperfections from the head which allows smoother circulation of fuel, air and exhaust. this increases performance and efficiency.
Free Flowing Exhaust/ Intake- take time to study the stock muffler on these engines and you will discover that the stock muffler restricts airflow, which often bogs down the engine while the stock intake does the same too. installing free flow machinery on both sides will contribue to performance increase.
Spark plugs- hot rodders have used "indexing" the spark plugs near to the exhaust valve which helps the engine to get rid of exhaust gases much faster. there is another tip that is used on spark plugs is to increase the gap between the electrodes to burn the fuel air mixture much more properly and efficiently
Check gaskets and other fixtures- always check for gaskets near important engine parts and trim them if they are blocking the path. every little bit counts here.
Carbs- lastly, the carb has to be tuned for getting more performance out of your engine, adjusting fuel air mix and trying bigger jets is a surefire way to increase performance.
I have tried to keep the information as accurate as possible, any suggestions are welcome to correct the above article.
Regards
DMCdesign
Regards
DMCdesign
if these heavy flywheels are polished (and/or) precision cut along with exact angles, I may have a lighter flywheel........
