My go kart has an 8hp B&S with a torque converter. I took it out for a spin today. I started her up, and let it idle for a good minute. I so much as touch the throttle and it tries to die. Eventually after several more minutes it's a little more forgiving. I hop on, and take it down the road a ways. I turn around to come back, and all is well until I hit the uphill incline, which was very minimum. I began giving it more throttle, to no avail. It wouldn't rev up anymore, and it became somewhat unresponsive to throttle input. No matter the throttle, I barely made it up the incline. I haven't tuned the carb yet, but it seemed fine for the first bit. I tried turning IN the idle and full throttle mixture screws, because my friend suggested it might be running rich. I tried to start it up after that, to no avail, even after returning the screws to where they were. Another thing is that my throttle cable is attached to the governor arm, which in turn is attached via rod to the throttle valve on the carb. Is this interfering with the action of the governor? It seems like since I am pulling in the arm with the cable that it wouldn't be able to move back up and close the throttle. Any ideas? I'm quite lost right now.
