trying to start a tecumseh 5.5 ohv, cant hardly pull the cord
beansdaddy78
JR. Member
Carbondale IL.
I'm out trying to start the 5.5 ohv motor that came with this murray kilowatt (i think)
It's not on the kart at the moment but I justp held it down and. Pulled on the rope good and felt like it about ripped my arm off the ripped the handle out of my leathery hands , but kinda hurt.
I guess it should be mounted before i try to pull it, but I have aoways been able to pull the cord on the motors while they are out,
Is there any reason It's so hard to pull, I'm mounting it now to see how much that helps
beansdaddy78
JR. Member
Carbondale IL.
Nope, putting the motor on the kart didn't help one bit. It still is ripping skin off my hand
Please someone tell me, or help me figure out why It's so hard to pull
beansdaddy78
JR. Member
Carbondale IL.
Just realized, It's only hard to pull at one point in the cycle, of the flywheel spinning around, kinda like i speed bump in the pull start.
Not sure if anybody can make sense of that
fowler
Bullsbrook West Aus
if the engine sat for a while then fuel may have leaked into the cylender
take out the spark plug out and turn it over
other wise souperman is probs on the money
Rustydog2010
NZ Nutta :|
New Zealand
Are you sure its not just hitting compression? Does it happen every four rotations?
If it's waaay too hard to pull through the compression stroke, check the following-
1) Ignition timing. A sheared flywheel key can do this. Disconnect the spark plug lead and try pulling. If it still feels the same, that's not the problem. If it just got a lot easier, key may be sheared.
2) Hydrolocked engine- Cylinder full of water, gas, or oil. Remove spark plug, and pull rapidly several times to clear any fluid out of cylinder. Keep your face clear of the hole. If this was the problem, investigate/repair cause and change oil immediately.
3) Valve lash- if it's way out of spec, it will nullify the effect of the "easy start" compression relief mechanism. Restore valve lash to spec.
beansdaddy78
JR. Member
Carbondale IL.
it happens every single rotation, im gonna go out and pull the plug and try to clear the cylinder. I am hoping thats the problem seeing it seems the easiest to fix, i hope :p
beansdaddy78
JR. Member
Carbondale IL.
Pulled tge plug It's easy to spin now, I tried pulling the cord to get gas out but nothing happens, how can I get gas out if there is any in there? Should I change oil before I even try to start it?
IF a hydrolocked cylinder was your problem, you would have been well aware of liquid or mist shooting out of the cylinder. Since it didn't happen, run the other test I laid out for you. Try it with the plug in, but NOT connected to the wire. If it's hard with the spark plug lead connected but easy with it disconnected, check the key. If there's no difference with or without spark, check valve lash against spec.
beansdaddy78
JR. Member
Carbondale IL.
would you havppen to know what the numbers are that i need for the valve lash? i borrowed a feeler gauge from a guy down the road but cannot find info on this motor for nothing. its a oh195xa tecumseah 5.5ohv
check your other thread... (which is why we prefer to avoid multiple threads asking the same question)
beansdaddy78
JR. Member
Carbondale IL.
i apologize for the extra thread, i was just being super impatient. my daughter was napping which is the only time i get to work on the motors and karts and i was just trying to get some info quickly.
once again im sorry, ill do my best not to let it happen again
No harm, no foul. Fuhgeddaboutit! But- you now can see the difficulty it causes. We struggle to keep up with the question, and you struggle to keep up with the answers...
beansdaddy78
JR. Member
Carbondale IL.
are lash caps needed for the motor to run, i just watched another youtube vid that showed there were lash caps on the valves and mine dosnt have those. are they able to be ordered, are they needed??
beansdaddy78
JR. Member
Carbondale IL.
Ok I'm pretty sure i set the valve clearance on the tecumseh ohv 5.5 properly, but I still pet the speed bump in the pull start cycle. It rips it out of my hand when i really try to pull
The kid I got it from said he used a huge drill to start it, would that have anything to do with it.. obviously I'm fishing for a solution and making stupid guesses now
fowler
Bullsbrook West Aus
Feed clean rope into the cylender to stop the engine turning
Nylon rope is best as u don't want any fibres left in the cylender
beansdaddy78
JR. Member
Carbondale IL.
dang, this go karting requires a lot of different tools and supplies. Unfortunately i dont have any so im gonna have to go spend more moneys on some rope, unless you can think of a quick alternative
i just tried to pull the flywheel and that sucker is on there, cant even get the bolt to break free, even with my breaker bar
