- Messages
- 9,157
- Reaction score
- 4,128
Just to be sure, make sure you're not running the engine with the air cleaner and the recoil starter assembly/blower shroud off. The former is because (duh) engine damage from dirty air particles and the air cleaner affects the fuel-to-air mixture. It's basically running leaner with the air cleaner removed and so all carb adjustments should ideally be made with the air cleaner installed (unless you're an expert) to maintain consistency.
Don't do the latter because the forced-air cooling from the flywheel fan/blower is totally negated with the shroud removed. It will overheat unless of course you're running down the highway at a constant 30+/- MPH.
