Too easy. I like to junkyard s**t like that. Think mopar ignition.For Injection look to Echotrons or something like that
True Dat!Giving him the credit card still has to be cheaper than giving it to the wifey
You sure it's threaded in???Well here is the mystery part Du Jour.
This thing fell out when the head was removed. Fell on the floor before we could see where it came form. Can anyone identify it?
Honda GX 390
It is only about .020 thick.
Next question. How does one remove this governor gear?
The shaft it is on is threaded into the case, but the gear and the innards spin freely on the threaded shaft. I see only two options to remove it.
1. Cut the f***er off with a angle grinder.
2. Bend the centrifugal weights out of the way and see if it comes apart.
I don't bother threading it. Lock tight and a 1/4" battery impact takes care of it.No, l’m not sure, but that makes sense. So if thats the case, thread the hole and plug it with a 1/4x20 bolt?
I heard they were worth only 5hp. What’s the real story?
Depends on who’s tellin the story.I heard they were worth only 5hp. What’s the real story?
