Torsk (Backbone Chassis) Kart
Took 'er outside to get the wheels on & finish 'er up :thumbsup:
Slid the axle thru the housing
...centered it
...& installed a bearing/spacer on each side
Measured the components keyways
Then, measured, marked & cut the keys
…~1" for the sprocket
…~2 1/2" for the brake drum
…& ~3" for the rear rims
Installed the brake drum on the left side
...the sprocket on the right
…& also the rear wheels
Time for a quick systems test (just double checkin') :cheers2:
Lastly, I threw the front wheels on
(gonna try the ones with the plastic rims, first)
Here is the final assembly video :2guns:
https://www.youtube.com/watch?v=UDCMetRDGdA
Forgot some stuff :idea2:
Once the sprocket was on, I installed the chain & adjusted the motor/chain
Went to slide the right wheel on
...but, it will rub against the tire
...so, gotta add a spacer
Positioned the wheel where it should be
…marked it
...cut a spacer
…& reinstalled the wheel
Yup, that looks better :thumbsup:
Atlanta, GA
I admit I skipped through most of the video, but it looks like fun. How does that brake work? It's fascinating.
Brakes?
...we don't need no stinkin' brakes :lolgoku:
...just, use the force :thumbsup:
Yup, brakes are still on the agenda :cheers2:
I got a brake lever & drum, just gotta get/install
...a cable, a brake band & a mount
Awesome! Looks great and seems like it drives really well too.
How do you like it?
What more do you want to do to it?
Thanks
I like it & it rolls out pretty good :thumbsup:
Next,
...brakes
...speedometer
...battery covers/hold downs
…& eventually, a paint job :thumbsup:
Issues/adjustments,
...steering seems "heavy"
...seat (bottom) seems kinda small
...the Amp/Volt meter readings seem "jumpy"
...the thumb throttle acts "weird", it seems to have a "dead spot"
When running at full throttle, I notice a "miss"
...I can physically feel & can audibly hear, the motor is NOT running at full speed
but, if I "back off" just a bit
...I can hear the motor "smooth out" & feel 'er speed up
Throttle issue? :idea2:
Atlanta, GA
Don't take this the wrong way, your build threads are excellent, and the karts you are constructing are wonderful, but you Sir are cheating the barber.
Thanks! :thumbsup:
"That's what he gets"
Barber!?
...we don't need no stinkin' barber :cornut:
"Oh say can you see ...my eyes
If you can...than my hairs too short!" :cheers2:
* Built in/on helmet :2guns:
I have put probably ~20 miles on the Torsk so far :thumbsup:
First thing that gave up/failed were the "ceramic bushings" in the front wheels :ack2:
Don't know why they call 'em ceramic?
...they seem like plastic to me
But, so far, I really like these plastic wheels ~$7.00 ea.
https://www.surpluscenter.com/Wheel...0-6-Carlisle-Wheel-Tire-Assembly-1-116259.axd
...their super light
...seem really ruggedly built
…& they can be (pretty easily) converted to "real" roller bearings
BMI has these low speed "flanged" bearings ~$2.00 ea
https://www.bmikarts.com/Flanged-Wheel-Bearing-58-x-1-38_p_1607.html
or these high speed "snap ring" bearings ~$2.00 ea. too
https://www.bmikarts.com/High-Speed-Wheel-Bearing-with-Snap-Ring-58-x-1-38_p_1608.html
Yup, I got the high speed ones :2guns:
...picked 'em up from a local shop "Homers Cycle Shop" here in Toledo, Ohio
...gotta support local businesses :cheers2:
The steel bearings fit into the plastic rims, pretty snug
...but, I could turn them (just a bit) by hand/finger
Don't wanna "spin a bearing" so I added a little "traction"
...a couple of "light" coats of liquid electric tape
…now, they fit good-n-snug :wai:
I also installed a ~50" brake cable & a 4" brake band
...but, it didn't seem to work too good (at first because)
I installed it backwards :lolgoku:
The "pull" has to go with the direction of rotation
...not against it
When the brake band pulls with/toward the rotation of the brake drum
...it "actually" helps the braking action by kinda sucking it in tighter
When it pulls against the direction of rotation
...it does the opposite & "tries" to push the brake band "open"
So far, I love these plastic/composite (front) wheels :thumbsup:
…& the "new" bearings are "way better" than them plastic/ceramic bushings
Even the (2 ply) "wheelbarrow tires" seem to be holding up pretty well
...but, I want to get the "proper" heavy duty (4 ply) "ribbed" tires, that match the rear wheels, on 'er :2guns:
Where is my "air chuck"? :idea2:
RickyBobby
Funny, I was just looking at making a kart with this motor yesterday. Looks as there are two versions of the my-1020 motor brushed and brush-less which one did you use and do you think the extra price for brush-less is worth it? Also on your little amp gauge. What is the maximum amps you saw used during a hard acceleration? If it stays below 20a, the battery's are much cheaper.
Another thing, and you may have already covered this, I read most of your 9 pages but really fast. It would be nice if you had some sort of battery cover. I suppose you could make one with some thin gauge metal or aluminium sheet using a metal brake to form a u-shaped cover to fit the length of the battery packs but I had an idea from another project and that is to use heavy gauge sheet of some type of Acrylic or Lexan plastic laid over a fabricated wooded box. then use a heating element strip like this https://www.tapplastics.com/product...lies/plastic_bending_strip_heater_element/169
to heat the joints and fold the sides over to make a lightweight cover for the battery tops and fasten with velcrow or what ever attachment method you wish to use. The plastic could then be primed and painted to match. Just a thought to keep the connections covered from shorting and the elements.
I just built a full-out rail buggy kart for my kid I just posted here on this forum as well as just completed a fairly mint Manco Dingo restoration I will be posting soon but my real hobby is electric bikes and I have been wanting to building something very similar to this for a while now. I made several notes and will steal some of your ideas like the steering wheel. Good Idea on that! But I had planned on using a li-ion or li-po battery pack on mine. You can pick up some really cheapones on aliexpress like this one here
https://www.aliexpress.com/item/48V...7f32-452f-a3fc-b72050cfdddb&priceBeautifyAB=0
Those 12v12ah deep cycle cells I see being used for the electric scooters or comercial electric go-karts as going for 50-55 each times 4 thats 220.00 and to me the li-ion packs can be had for just a few dollars more and are only ~10 lbs and can handle a lot more cycles
Great job on the kart though. The design reminds me of the Z-kart I saw a few years back.
https://www.google.com/search?q=z-k...8d_cAhUGWK0KHe6yCIsQ_AUICygC&biw=1600&bih=755
