Torquing rod bolts?! (Please help!)
jr dragster T
Cold place
You could buy a bulley go carting clutch or a noram clutch. The noram is around 130 and the bully clutch is moderate maintence but there kinda expensive 200-400 I think.
oscaryu1
Secondhand clutches here I come! :D
How well do you think a heavy-duty "Max Torque" clutch will do for a while?
What maintinance does it require other than a rebuild once in a while and a bit of oiling? (new clutches that is)
jr dragster T
Cold place
if you get a bully clutch or a steller clutch there VERY ajustable and require frequent maintenece. you need to clean them out about every 1 hour of run time. just google search bully kart clutch. Its what the pro's use. but a max torque clutch would work for a while. but a max torque clutch engages at like 2800 but a bully is ajustable. And normally high performance engines like yours and mine need to idle a bit higher than a stock engine.
oscaryu1
Hmm... you have a point... is it normal for a modified engine to idle rather high?
oscaryu1
I do, but usually it's either stuttering at lower speeds, or smooth idle at higher speeds... Maybe jetting too low? I'll have to do a plug reading.
jr dragster T
Cold place
Its not just a matter of adjusting the idle Kenny. Mod'd engines have lots of compression and very stiff valve springs and will just kick back if not idle'd high enough.
gocartkid
Bad Attitude
CT
EXACTLY. That's why my dad's race-prepped chevy 283 only wants to idle at 1200rpm.
jr dragster T
Cold place
Yeah go kart kid you know what im talking about. Espeiclly if the engine runs on alcohol it will not like to idle low at all.
oscaryu1
Oh goodie. 26lb springs, 6cc smaller head, SS Valves, new seats, flat top piston, and new rings.
I'm not sure how much compression it has, but it has enough for you to lift it up and swing it around.
If possible, couldn't I just open up the clutch and install stiffer springs? Of course then there's the question of how I'll put it back together.
oscaryu1
What's a medium class clutch you'd recommend me installing? (In the 50-80$ range)
jr dragster T
Cold place
I dunno I tried to do some re-search for you but it seems like its "go big or stay at home" (meaning pay 39 bucks and burn it out in a month) or pay 120 for a NORAM and it will Last and last and last like the energizer bunny:roflol:
oscaryu1
I thought the bunny died? :D
Anywho... I'm just gonna use up the old max torque clutch and see what happens!
oscaryu1
Went to Sears today and bought a 12 point 1/4" drive socket, a 1/4" to 3/8" adapter, and a 3/8" torque wrench (inch pounds).
$80 :eek:
Just noticed why that 1/2" drive wrench was so expensive. It was a torque wrench too! Good ol' lowes.
oscaryu1
I had a Kobalt 1/2" Drive torque wrench. I didn't know what it was... didn't even know the price at the time.
At checkout... "$90?!?! It better be worth it..."
Today, while working on my car, the bolt blew off. ARGGGGG :mad:
