shelby1
Ok if any off you have fallowed what I have done with my grand sons Murray kart, well he has gone tru 3 drive belts with 2-3 hours run time , the first was because I did not line up the drive and driven pulleys, fixed that and two more belts ( at about 25 bucks a pop) burned and rolled on the flat side. Ok I have went back tru every thing on the kart and I have two questions, the large nut on the driven pulley , according to instruction sheet the tighter the nut is the higher the rpm that it will shift from 1:1 to .95:1...... I wondering that because the nut was not tight enough and it was shifting to higher ratio ( lower number ) and causing much harder drive pressure on the belt.
The second question is the gear ratio may be too tall ( lower number wize) as the primary sprocket is 10 teeth, driven sprocket 36 teeth which is 3.6 :1 with a 16 " wheel ...... to my way of thinking I,m thinking it should be around 5 to 6 to one.
Help me Guys!!!!!!
Help me Guys!!!!!!
except I don't drink coffee.
