Torque convertor problems / wrong gear ratio
shelby1
LA..... Lower Alabama
Ok if any off you have fallowed what I have done with my grand sons Murray kart, well he has gone tru 3 drive belts with 2-3 hours run time , the first was because I did not line up the drive and driven pulleys, fixed that and two more belts ( at about 25 bucks a pop) burned and rolled on the flat side. Ok I have went back tru every thing on the kart and I have two questions, the large nut on the driven pulley , according to instruction sheet the tighter the nut is the higher the rpm that it will shift from 1:1 to .95:1...... I wondering that because the nut was not tight enough and it was shifting to higher ratio ( lower number ) and causing much harder drive pressure on the belt.
The second question is the gear ratio may be too tall ( lower number wize) as the primary sprocket is 10 teeth, driven sprocket 36 teeth which is 3.6 :1 with a 16 " wheel ...... to my way of thinking I,m thinking it should be around 5 to 6 to one.
Help me Guys!!!!!!
Yep, assuming you have around 5-7HP engine, with 16" tires, Replace that 36T with a 60T.
How fast did your grandson go?
If it ever hooked up properly.... It was geared to do 52 mph at 3600 RPM.
Bbqjoe
Banned
Location, Location
Help me Guys!!!!!!
Maybe I smoked too many marijuanas with my coffee this morning, and unless your driven is different than the three I own, I've never seen ANYTHING about tightening the nut to adjust anything about shifting.
:iagree: except I don't drink coffee.:sifone:
From what I understand you have to swap the driven spring or change which preload hole that it is installed into.
shelby1
well I thought that it was a little strange for the instruction sheet to say that .....cause it did not really make sense to me but I am new to the torque belt set up so......did not know any thing about it. I will bring the instruction sheet home and copy and post it for all to see.My main concern was about the final ( chain drive ratio ) as how it compared with tire size. On the racing karts that I worked with years ago the final drive sprocket was not much smaller than the drive wheels .And when your butt is only a inch off the ground it was scary how fast those karts were.
Kenny
---------- Post added at 02:42 PM ---------- Previous post was at 02:37 PM ----------
Oh now that is just scary .......that boy only knows one speed ........and that is wide open, thank goodness there is no wide open spaces where he rides , only a acre that is on the rough side and no long runs.........
Kenny
