kendelrk
redneck engineer
so im planning on getting the torque converter for my baja when i get the cash, ive heard that it basically disables the governor. I heard the load from the torque converter disables the governor but keeps it around 3500 ish rpm, is this true? What speeds am i looking at from a stock baja heat with a torque converter? Also, when i took out the throttle stop screw on this motor it was very unsteady and full throttle, it acted like it had a burst rpm and it wouldn't stay constant, it would basically surge, but if i let up on the throttle a little bit it went just fine, is this an engine problem?and also, after about 15 seconds of running, the exaughst starts to smell like its burning, its oxidized a little bit, but is the smell normal?
