Torque Converter Help
That’s about it.
Now make your own calculators on your Microsoft sheets or what ever free excel is now
Bob58o you remind me of a former member Bobo. He was some kind of math/ theoretical physicist/genius/bartender at stripclubs kind of guy. He was a he11of a good guy. He used to do like you and get all mathy for us dummies. You probably never heard the term GAB=Going all Bob. That’s when one gets an answer to many questions they did not even ask yet.
I for one Thank You for GAB! While I may not care or remember all of it it will come in handy in the future.
Holy snapping arshols Matgret! We have a living legend amongst us! Why the new handle? How’s the strip club scene in Chicago?
Not a new handle. I don’t think. I think this has always been it. Jake Arrieta’s head on Muhammad Ali’s body has been my photo for a while probably 2016
River_10
Queensland, Australia
Hi guys,
Was wondering if a Comet 40 series would work on a 420cc 16.5 hp engine with a #41 60 tooth sprocket on the rear axle? Also, do you know what chain would work with that? Or should I use a different rear axle sprocket? Any suggestions or information would be greatly appreciated:)
Thanks
Hi guys,
Thanks
Maybe start a new thread. Include your tire size the vehicle in question and type of driving.
This thread was hijacked many times over.
Barnfresh1
And as far as tuning, you’re best bet for performance is to set clutch engagement at peak TQ.
IMO if the engine makes peak torque at 3000 RPM, for top performance, the clutch engages at 3000 RPM.
If peak HP is at 4500 RPM, you want to stay around 4500 while the CVT is shifting through its range, then rpm will continue to climb as speed increases past peak HP until you reach top speed
Ok so RPM is another thing that makes me go huh. Currently the (standard) 2200 RPM engagement speed is lower than my li’l engine’s peak TQ which is listed as 3000 or 3250 RPM depending on which spec sheet you go by. Unfortunately I’ve never found a graph anywhere that actually shows the torque or HP. I’m guessing based on other small industrial stock engine curves the HP should continue increasing and peak somewhere in the mid 4000 RPM range when ungoverned as mine is.
So knowing full well I’m still over-geared what advantage might I expect to see by bumping the engagement speed up to 3000 RPM with a set of white springs? Will it also raise the RPM speed closer to peak TQ during acceleration or just during initial take off from dead stop?
My max RPM was 6400 at top speed with the old centrifugal clutch & chain setup, now it maxes out at 3550 RPM. Am I correct in assuming that simply raising the engagement speed to match the peak TQ will have no affect on max speed/RPM?
Should I only expect to see the RPM increase beyond 3550 once I reach that mystic ‘Ample’ sprocket ratio Comet says is required for maximum CVT performance?, that is providing the engine has enough power to begin with. I’m not expecting it to ever reach the RPM it did with the clutch due to losses in belt efficiency and slip however a little increase would be welcomed.
A lot of assumptions there and Yes I’m well aware of what happens when one assumes hence all my questions.
Bob, I told him to ask here your opinion mathematically of course. Just to keep this valuable information in one spot. Seemed like a good idea? He already knows my opinion.
I think you are correct that changing the clutch engagement should not have too much change on your top speed.
There seems to be an issue other than fine tuning the TC. I don’t yet understand why you lost half your RPMs. Did the sprocket ratio change? I would expect the rpm’s to stay around a certain range while the TC is shifting through its range. Are the mph’s climbing while rpm’s are sitting around 3600? I guess it’s possible that you might sit around 3600 rpm until it’s fully shifted, then continue to climb rpm’s once the TC goes through its range.
How are you measuring RPMs? Hour-meter? Is it set to correct mode? Sometimes it reads double or half if it expects one spark and gets two or vise versus.
Did top speed drop? Is the belt aligned? I’m confused and don’t remember what project I’m talking about anymore. I feel like there’s a lot going on in this thread.
Sounds like someone needs a lap dance!
After my 2 cervical surgeries I’m on a bunch of gabapentin and sertraline. Helps with burning sensation from nerve pain, but produces a bit of brain fog.
I’ll set something down while using it, lose it, start to look for it, forget what I’m looking for or what I was doing to begin with.
Dementia is going to be a blast.
You had your cervix operated on? I have a titanium plate and screws along with some stainless steel wire in my neck. I had to get away from the gabapentin. It made me nuts if I did not take it! Highly addictive! I live with the nerve pain and numbness. It sucks!
