Torque converter, driven unit damaged, how/can I fix this?
Dvrice
My belt broke and jammed in the driven unit. I thought it was just a broken belt and replaced the belt. When I put the ne belt on, the belt didn't engage when I pressed the gas.
When I investigated the problem, the belt had "too much space" in the driven unit. I removed the driven unit and inspected closer. The spring in the driven unit is loose (spins freely). It looks like the tail of the spring needs pushed back down in a hole. There are three holes labelled 1, 2, and 3 and I'm not sure which one to put it in.
Also, on the inner side of the driven unit there are little plactic caps over the tabs that extend and touch the tabs of the other half of the driven unit. All three of these plastic caps are now missing. They must have been knocked loose when the belt broke because I remember them being there before. Can i purchase just these little caps?
Thanks for the help!
Blazkowiez
Kart Aficionado
Houston, Texas
First hole. Check to make sure the spring isn't sprung, also the cam buttons can be replaced. There are several threads regarding this problem. Do a search and read up.
Dvrice
What do you mean to check the spring hasn't sprung? Do you mean is it broken? Or worn out? Or what?
Thanks
Dvrice
The spring is intact, but seems like it may be a little weak. If the spring has weakened a little over time, should I try mounting it hole 2 or hole 3 to compensate for that? Or just still go with hole #1?
Blazkowiez
Kart Aficionado
Houston, Texas
try all 3 holes......and see what works best for your setup. with a little practice it can be switched in about 5 min.
You realize as explained to us by one of the engineers at COMET those holes do nothing for stall and work as early engagement.
At the end of the day on a diy website listen to whatever advice you want, I've said my bit.
