If you read the spec on this Link it say not for 7" driven
Is there an answer to either one of my questions in there somewhere?
Show me where you are getting this 30/31mm thing from.
Well, I'd really like to know the source of that 30/31mm thing. Might be useful, might be unrelated.
Have a look at these charts-
http://www.gokartsupply.com/beltchart.htm
http://www.gokartsupply.com/tcbelts.htm
I don't see a metric measurement there anywhere.Thats where i got it from where it say belts size under driven and 5/16
Okay- so have you figured out which belt yet, according to the charts?
I did. Need to measure exactly bolt center to bolt center, the distance between driver and driven, then match that number on the chart under 7" driven.
I have the same resources as you do, when it comes to seeking out a replacement part.
I just want you to find another carburetor aftermarket and not the original the will fit that part number
EDIT: There are too many variables in aftermarket carbs for anybody but you do wade through and decide what you want.I just want you to find another carburetor aftermarket and not the original the will fit that part number
About the only thing that will fit with no modifications is an original part. Anything else and you're going to have to do some modding.
Well I found what I needed and I just ordered them I ordered a asymmetric belt and a new carburetor I wait till it comes and I'll see if it solves my problem thank you for helping I'll be back with this theard after I install the parts
So you figured out what belt you need. I hope so, otherwise you are still going to have problems
I bought part number 203592 for the belt for comet
