Torque converter/clutch
trekklee
Hi I have a comet torque converter/ clutch an I want to know the size belt I'm Suppost to use I use a v belt but it keeps on stripping it and it snaps I'll post pictures later
trekklee
If that's the case, then we need not confuse the issue. It is a CVT (torque converter), period. While a CVT does perform clutching duty, it does not "have a clutch, too".
Ok I have pictures here sorry it took me soo long
That is a 30 series/ TAV2 CVT. It requires a specific, asymmetric belt, not a V-belt. If you have been using the wrong belt, than that certainly would be why it's getting chewed up. Offhand, I think you need a Comet 203589.
trekklee
You sure i should buy that one?
I just want to make sure before i buy it
trekklee
How do you measure the driven side cause there are belts for 6" and 7" drivens but idk how to measure it
trekklee
The 6"/7" is measure of the driven's diameter (the driven is the second pully...the one not on the engine). Measure the diameter with a tape measure.
Do I measure side to other side or middle to right or left to right idk I'm confused
