Hi I have a comet torque converter/ clutch an I want to know the size belt I'm Suppost to use I use a v belt but it keeps on stripping it and it snaps I'll post pictures later
Is it a torque convertor OR a clutch?
My torque converter has a clutch on it I want to know the belt size for it
If that's the case, then we need not confuse the issue. It is a CVT (torque converter), period. While a CVT does perform clutching duty, it does not "have a clutch, too".He is talking about the driver.
That is a 30 series/ TAV2 CVT. It requires a specific, asymmetric belt, not a V-belt. If you have been using the wrong belt, than that certainly would be why it's getting chewed up. Offhand, I think you need a Comet 203589.
The 6"/7" is measure of the driven's diameter (the driven is the second pully...the one not on the engine). Measure the diameter with a tape measure.
Its just a circle. One side to the other is fine.
Did you read that maintenance thread?
What's this 30/31mm thing? What are we talking about?
