Torque Converter AND a C. Clutch
Filipe
06095, CT
I'm looking for a dingo, and I found one where the owner claims to have a TC and a C. Clutch, thus having a "secondary gear". Does anyone on here know what that means?
Rochester, MN
lol.... yeah, sounds like a scheme to make it seem like it's worth TONS AND TONS of money. Unless he's "throwing in" a separate clutch with his kart.
Filipe
06095, CT
Could you post some pictures please?
Have no pictures of it yet...
I don't know if he's trying to set me up... It's a 5hp Dingo for $250-300. He said its in pretty good shape, only rode for 110 hours, no rust, good tires, etc. He's 5'-11 and claims to hit about 35MPH.
Is a C. Clutch and a TC on the same cart even possible?
klicky96
Sandusky, Ohio
It's possible but people don't do it because the driver unit is the clutch for the drivetrain and you wouldn't need a clutch
Filipe
06095, CT
so is there any benefit to this? I'm new to carts, so I don't really understand how the two would work together.
Bluethunder3320
definitely isnt stock. and its worse because a torque converter already has a clutch system to let you idle. so adding a cent clutch adds unnecessary slipping and youll lose some energy the more complicated your gearing is from resistance.
Filipe
06095, CT
touche, I'm no cart genius, but I took physics. more resistance=loss of energy
so, this "secondary gear", it's B.S?
Bluethunder3320
yup! but ask him for a picture, thatd be cool to see how he supposedly did it.
with a torque converter, it has unlimited "speeds" it always changes the ratio to get the most out of your engine, wether you need torque to get up a hill, or speed on flat ground, it automatically "slides" ratios. you wouldnt need an extra gear.
Filipe
06095, CT
will do. he said I should have pictures by friday afternoon. I'll post them on here.
I should read up more on this TC stuff. especially if I buy a dingo...
Also, while this thread is still active, any idea where I may be able to buy a throttle cable for a dingo?
B.M.800
TheBeal.
Central PA
Keep in mind, the seller may not realize what the statement sounds like...
They may be getting something confused here, people do infact make mistakes.(big surprise eh?) He could be referring the driver as the C clutch, it does use the same idea as to how it works...
Filipe, the "secondary gear" could very well mean the different gear ratio the TC provides... as Ive head a TC related to a 2 speed automatic tranns, makes sense to put it that way to me.
Untill we see some pics, we cant say the seller is full of crap.
{EDIT} wow... nearly 5 mins to write this post... lol.
:D
Filipe
06095, CT
I'm not sure...this is how he puts it:
"its got a torque converter and has a centrifugal clutch so it has a secondary gear,"
I'll be sure to post pics on Friday, please be on the lookout!
Mcbreja
Arlington, TX
As for the throttle cable, I think it was go kart supply that has cables specifically for the dingo, but they are ridiculously expensive. You are better off making your own with cable from your local hardware store.
Filipe
06095, CT
Yea, like 22 bucks! :mad2:
