4.2.2 Initial settings
Turn both jets in until lightly seated. Turn the High jet out to 1/3 turn on cold days, 1/2 turn on hot days.
Turn the Low jet out 11/4 turns on cool days and 11/2 turns on hot days.
4.2.3 Jet Adjustment
The engine should run OK with these initial settings, but will require tuning to achieve best performance.
Note that if the mixture is too weak it can result in damage to the engine.
• If the engine smokes and four-strokes at corners then the mixture is too rich. Weaken the mixture by closing the low and high jets together in increments of 1/16 of a turn.
• If it is slower than others along the straight because it won’t rev high enough (i.e. It flattens out at below 15000 and sounds ‘fluffy’) then it is too rich at the high end. Weaken the mixture by closing the high jet in increments of 1/16 of a turn. If the track temperature is high then turn the low jet out by equal amounts.
• If the top end fades or pops and spits then the mixture is too weak. Open the high jet in increments of 1/8 of a turn.
• If it has poor pulling at low revs coming out of corners, but no engine smoke is visible. The mixture is too weak at the low end. Open the low jet in increments of 1/8 of a turn.
