Tire size question?
RobbieGreene508
I just bought a set of used tires on 6" rims; the current tire size is 12x8x6; HOWEVER; for the project I'm doing I need a 10" diameter tire. It was too good of a deal to pass up, even if I have to sell/trade them away, but I haven't found a 10" tire that'll work (& I don't know my *** from my elbow with kart tires/wheels). Anyone have any info/insight or links that can point me in the right direction, or a size to look for that'll work?
Thanks again fellas!
chancer
ɔ ɥ ɐ u ɔ ǝ ɹ
COMFORT, TEXAS
What is wrong with 12" tires? If you don't know your but from your elbow, How are you so sure you need 10" tires? I would bet the 12" tires will work fine.
well 12x8x6 sounds like std racing slicks...
And I'm afraid to tell you, if you're very very lucky you can find a set of 11.5x8x6 slicks (or even wet track) from Dunlop...
smaller diamter for 6" rims are not available as far as I know.
When you MUST have 10" ers (oh boy.. I smell PVC pipe...)
then you'll have to have a narrower 5" rim (wider than 5" ones are no smaller than 11" as well )
the rims Chancer is currently selling in another thread for example.
RobbieGreene508
Ok, to better clarify this is a motorized drift trike project with/for my son, and therfor pvc "sleeves" will be wrapped around the tires . 12" tires MAY very possibly work; however, 10" pvc can be locally purchased and readily available whereas 12" is special order and EXTREMELY expensive from what I've seen; as in around $100 per foot or more plus shipping; 10" is around $30/ft give or take. Seeing as the pvc will be quickly abused and will constantly need to be changed out, I'd prefer the smaller available stuff. Otherwise I might as well skip the pvc and go with just baking the rubber tire; because new tires will actually cost less. Nevermind the fact that deapite his current interest and excitement, my son may only use it for an hour and park it to rust away. I'm trying to be as frugal as possible for the initial build.
As for the tread/turf: slick is obviously best for full contact, but others can be used. You deflate the tire, push/force the pvc over them, and air back up to hold them on... That's why I initially went with used tires that are basically junk for race use and were to be tossed out. Some people even use adhesives and caulking; especially with a "non-slick" tire. I'm fine with that route.
... called it!
Anyways, hmmm nope
https://www.alibaba.com/product-det...60163653612.html?spm=a2700.7724857.0.0.IMOwYO
300mm pipe is what you want.. unfortunately your imperial system makes it hard to find :D
hehe... sorry... LOL... can't help it ;)
Aaaanyways, alibaba offers 4m (~12ft) for ~10 USD... enough for a fleet of drift trikes.
how far are you away from the canadian border?
Any chance of a short trip to buy metric pipe?
chancer
ɔ ɥ ɐ u ɔ ǝ ɹ
COMFORT, TEXAS
I see this green PVC at Road construction sites. It is used for drainage. Maybe you can find one of those underground construction companies locally to you and get some 12" pipe. Possibly free. Sounds like you need 18" to 24" total. If they are running miles or long distances of this pipe a scrap piece that size may be trash to them and Gold to you.
Just a suggestion.
good point.. stormwater sewer pipes are generally a tad larger in diameter..
300mm (12") are not uncommon.. at least not in the metric world.
chancer
ɔ ɥ ɐ u ɔ ǝ ɹ
COMFORT, TEXAS
The Green stuff is Really thick wall too. May last longer than the white.
