Alright, well, I am by no means a master welder. I can weld something, and have it look..well, good enough for me. My welds are plenty strong, too. When I have a material I am testing with/setting up welder voltage/feed speed, I often give it the "sledge hammer" test, where I take it "out back" and beat it up
Here's a weld I used to set up the voltage/feed, to show what my idea of an "acceptable" looking weld is...
I know it's nothing to look at, but it's plenty strong, and looks good enough.
Now, here's where the problem is. All of the things I've welded are single beads (not stopping/starting again) and I have plenty of room to maneuver. Now, I was welding some 1" square tube onto some 1/4" steel, where I need to stop and start, to get the whole base welded, and don't have much room to work with-here's what I'm talking about--it's only been cleaned up with about 5 seconds with a wire brush--
The top and bottom bar are 3" apart. Since I've never welded things like this, not much room, and needing to stop/start the weld for each side, it looks like sh!t - here's zoomed in on the welds--
As you can see, along the side where I'm not limited in room, it looks up to my standards, like the first picture. On the sides though, it looks horrible. Also, you can see where I joined the first welds (area where I had more room to work) with the second welds, where I was somewhat limited in space.
Now, all of the welds on this are plenty strong, but it's the visual part that's bothering me. Any tips for getting better welds in areas like this, and any tips for starting/stopping the bead, and making it look decent?
Oh, and before you say it, yes, I know I need to practice this more. I just want to know if you have any tips/things to try/watch out for when practicing.
Thanks--
Also-please no "your welds suck" responses
I know they do already. Any tips for making the ones I call "acceptable" better would be great, too.
Thanks--
