Throtle linkage
GOFAST
Does anyone have a photo showing how the linkage is hooked up under the fuel tank on a 5hp Briggs/Straton go cart.
Engine No.136212 001601 95101307
Thanks for your help
acg23
bay area
you should remove the internal gov and attach the throttle cable to the butterfly valve on the carb. this will give you alot more speed. also it is very simple to do.
GOFAST
Already did that but am having problems reconecting the spring and cable.
Thanks
GOFAST
Where the cable from the foot peddle hooks up under the gas tank!
Thanks
acg23
bay area
i dosent. only way to controll the throttle is with the buttr fly valve on the carb.
