Does anyone have a photo showing how the linkage is hooked up under the fuel tank on a 5hp Briggs/Straton go cart.
Engine No.136212 001601 95101307
Thanks for your help
you should remove the internal gov and attach the throttle cable to the butterfly valve on the carb. this will give you alot more speed. also it is very simple to do.
