still not enough compression there, that was just an example
if u have a big enough weight im sure it will work.. if the bottle is tough enough also.. it probaly would just crack the plastic and leak out.
Okay, I think I get it now, Thanks all! Kinda mindbending when you don't expect it. Especially considering the old 1962 Dexta tractor I use for clearing scrub. It's got a 3cyl Perkins Diesel that's WAAAAY overdue for a rebuild. If it sits too long between uses (IE a few months) it will not start, not even with ether. I have to put oil in the cylinders via the intake or injector lines to get the compression back up to where she'll start. I believe it's because the rings are bad or the cylinder walls aren't in the greatest shape, so when it sits a long time, it loses the coating of engine oil on the cylinder walls and the compression's too low to ignite the mix...
