****This is new to me
freakboy
the names 'mater
hick town
it probaly has no cold starting ads like a glow plug... and spark plug.... if u were seriouse get the hell outa this thread.
mike75925
thinker and tinkerer
Alto, tx
as serious as seriouse and deisel. what's wrong fellas? the spark plug was about if meth had to be ran with a plug. i know on r/c glow works, but not on these types
freakboy
the names 'mater
hick town
u can run meth with deisel strait also propaine and other crap... you can run a diesel off old motor oil... ask anyone who has had a diesel run away turbo blows engine feeds its own oil into the intake goin through and basicaly makes it run like a bat outa hell.
mike75925
Alto, tx
yes, i am aware of Diesel's fuel flexibilty. the very first ones, if i remember correctly ran on peanut oil. but if running straight methanol, will it run without a glow or spark plug? i've read guys running 17:1 on a 6.5 and meth.
What I don't get is starting- It uses a compression release to make it easier to pull start...
How the he// does a non-glow diesel start with no compression???
freakboy
the names 'mater
hick town
probaly works at the lowest rpms till it gets some momentum then fires over. or just has somethign to do with releasing the compression till the cylinders get a good bit of fuel in em.
Kaptain Krunch
Pro Junk Collector
vermont
Kyle, my leaf blower is a caddy too, the liquid cooling was what added the extra 2hp. I was considering a sticker kit for an added 5-10 horse.
mike75925
Alto, tx
it is mechanically injected fuel, it won't fire without fuel. you have to get it to spin before it will send fuel to the injector. our clones on pull starting only have 60-90psi. when the comp release releases, it can go up to 160psi w/ a comp ratio of 8.5:1. the diesel, i believe i read has 19:1. if you didn't have a comp release, the rings were good, i doubt you would get it to pull start.
TurtleMann14
Insane plan member
West Virginia
compression release lets you get the engine up to speed and as soon as it gets there it goes to full compression and it starts firing
as mike said, you couldn't get it to spin over fast enough with full compression
and i am pretty sure that methanol in the injection system would kill it as there is less lubrication
freakboy
the names 'mater
hick town
Wouldnt A diesel with an ignition system would be a normal 4 stroke (or in some cases 2 stroke)...
a diesel with a igniton system would be useless. deisel isnt flamable unless its arosaled. or compressed... hold a lighter to a pool of diesel and see it not burn
yet throw it in a plastic bottle and then add a big weight to it and drop it off your roof and watch a boom.
Kaptain Krunch
Pro Junk Collector
vermont
Yea i know, but mike was saying something about sparkplugs with diesels...
