That's just scaryThis guy gets it. Lol
That thing looks like death. Rad ride, though.This guy gets it. Lol
I miss those characters Poboy Cartman, BBQ Joe and Chancer. I’d ride that bike I ain’t skeered.Sadly, nobody has seen BBQ Joe since that photo.
I'm not single or in crisis mode (yet anyways)It is appropriate living room decoration for a single guy having a midlife crisis. Lol
This is what functional art is all about!I'm not single or in crisis mode (yet anyways)
...but, I built a mini-Jeep in our rec room this spring
...& my wife just loved it (oh the memories)
* Nice work on your project & well explained
Personally my suggestion would be to look at full size motorcycle frames, custom or otherwise but hardtails specifically... then adapt the design to accommodate your engine layout (jackshaft?) and wheel size... rough guesstimate ⅓ scale maybe ½ at the largest.Still waiting on the front wheel, the seat, the front fender, …but I’m trying to figure out how to construct the frame.
I carry ones for fun, but for a green card I’ll sum em up real nice.I was only kidding man, I’m sorry. I won’t do it again.
I’m playing around with a few jackshaft ideas.Personally my suggestion would be to look at full size motorcycle frames, custom or otherwise but hardtails specifically... then adapt the design to accommodate your engine layout (jackshaft?) and wheel size... rough guesstimate ⅓ scale maybe ½ at the largest.
I do know that the head studs on the PTO crankcase cover side of the block are pretty much the centerline (same as the base mount holes on that side) of one of these engines fully assembled with a Tav2 hanging off 'em
Weight mostly, but that's not a fair figure to work from with a charger stuck to it.I’m playing around with a few jackshaft ideas.
Are you talking centerline being halfway from end of the driver pulley to side recoil cover? It’s about 14” across. It seems halfway (7”) is about where the spark plug is. Are you talking center of weight distribution?
I liked the way it is with the driven pulley just outside the lower rails.
Here’s a pic of the dark side of the moon.
My back has been hurting, and still missing a wheel so not much progress has been made.Weight mostly, but that's not a fair figure to work from with a charger stuck to it.
I also forgot That yes the spark plug is pretty close to the physical centerline on a full stock with the cvt driver mounted, but I've done a recoil delete on my shroud which moved the physical centerline over more inline with the left headstuds and deck holes
