Tecumseh Power Sport 6.0 issues..
that4wdwagon
I've got a Manco go kart with the Tecumseh Powersport 6.0 hp that I'm trying to get running as a Christmas present. I've rebuilt the carb twice and played around with it for the past week and I still can't get it to run perfect. When use the primer bulb to prime the engine I do it about 5-8 times and then I try to start it up, it will immediately hit and start up but then dies within a second. If I'm fast enough to hit the throttle before it dies then it'll stay running. All I have to do is hit the throttle real fast once and after that it'll stay running without me messing with the throttle. Once its running it kind of hunts/surges when idling and when it gets lower in the rpms it backfires. Every now and again it will just randomly die.. It may just be trash making it die but then why is it so hard to start it up? It also doesn't matter if the engines stone cold or if its been idling for 20 minutes. Its hard to start no matter what... Does anyone have any insight to what the problem could be? Like I said I'm kind of cutting it close considering theres only 4 days till Christmas, so the sooner I can get some advice, the better! Thanks in advance!!
-Dillon
Staff Murderator
It could be literally anything that is causing the stalling but what you have to do is ascertain that the carburetor (and engine) is setup properly, or at the prescribed factory settings for it to run right. Idle speed, fuel/air mixture, etc.
I would watch videos by the Youtuber "donyboy73". He seems to do a lot of troubleshooting videos on Tecumseh engines.
The Powersport engines are fairly desirable so it would be great to get it running as designed.
https://www.youtube.com/user/donyboy73
KartFab
Dallas, TX
How much is your time worth? I hate tecumseh engines. Crappy carb/linkage design. I can always get them to run, but never run right. A common problem the bulb style choke engines have is they suck, and the lever style choke carbs have less issues on startup.
Or you could just get a predator 212cv that starts on the 1st pull. Sell the tecumseh for $40 and cut your losses.
that4wdwagon
The only other thing I'm probably about to do it remove the welch plug and make sure everythings good there. Ive messed with tecumsehs before and have always got them to run really good, but this one just isn't wanting to run right... I would definitely get a new carb if it wasn't so close to Christmas, but it wouldn't get here in time and I really want this one running in tip top shape on Christmas Day. I don't know, I guess I'll go out and mess with it a little more tonight... The neighbors love me! haha
I have seriously thought about snagging up a predator, especially at that price, but I'm hard headed and am bound to get this thing running right hahaha.
Poboy kartman
Senior Moments Member
White Settlement Texas
Where are you located?
---------- Post added at 10:03 PM ---------- Previous post was at 09:58 PM ----------
A real quick thing to try ( works every now and again)..... Get that sucker fired up and running high speed, and clamp your hand over the end of the carb until it almost dies, then release, rinse and repeat ( just do it again).
Often the high suction flowing through the carb, then turned into suction throughout the carb, can free up passages and get things flowing.
that4wdwagon
I'm located about 20 minutes from the Talladega Superspeedway in Alabama.
Alright, I'll definitely try that tomorrow if cleaning the passages behind the welch plug didn't work. I also checked and reset the governor lever earlier just to rule it out(didn't change anything). I also might unhook the governor linkage from the carb and see if it still surges. I really just want it to start up without it giving me a hassle.... I can deal with everything else after Christmas when I get a new carb/predator haha....
Staff Murderator
I heard you can add some Sea Foam to the gas tank and run it through the engine to clear things out--sort of like an engine enema.
I understand the Sea Foam makes beautiful billowing clouds of smoke out the exhaust pipe...
that4wdwagon
That actually wouldn't be a bad idea, the piston looked like it had a good bit of carbon build up when I cleaned the spark plug. How much do you use for a go kart? I've used it on plenty of cars but never on anything like a go kart. And I know!!! Thats the best part of using seafoam is the free smoke bomb!!! :cheers2::cheers2:
chancer
ɔ ɥ ɐ u ɔ ǝ ɹ
COMFORT, TEXAS
I think they make one just for lawn mowers and snow throwers etc. same engine as a kart
Instructions would be on the bottle.
Staff Murderator
Well it's a ratio of Sea Foam to gasoline, just metered to the small amount of gasoline that our typical gas tank holds.
I don't know exactly, but if in doubt, read the 'destructions'.
Oh, and...
Staff Murderator
That actually wouldn't be a bad idea, the piston looked like it had a good bit of carbon build up when I cleaned the spark plug...
Well heck yeah! Scraping carbon deposits off of the piston and cylinder head IS part of our typical maintenance routines. But if Sea Foam can do the same thing as mechanical removal, I'm all for it.
I would bet the Tecumseh shop manuals are worded similarly to Briggs:
"One by-product of combustion is carbon, the black soot that can collect and harden on the cylinder head, cylinder wall, piston and valves. Carbon deposits in the combustion chamber can affect engine performance, resulting in higher oil consumption, engine knocking or overheating.
Using unleaded gasoline reduces carbon build up. As a part of regular small engine maintenance, you should still remove the cylinder [head] each 100 hours of operation and scrape off the carbon, using the tools and solvents described in this section. Clean the cylinder more frequently if you use your engine heavily."
https://www.briggsandstratton.com/na/en_us/support/faqs/browse/removing-carbon-buildup.html
